Simister--There is a trick involved here. If you block the carb inlet with your finger and turn the engine over, it will always pull fuel up the fuel line because of direct suction as long as the inlet valve and spring are functioning. However, for the engine to run in a normal manner without being choked by your finger, the vacuum created to suck the fuel up from the tank is created by venturi effect. This is essentially a low pressure area created in the carburetor by a narrowing of the air passage into the carburetor, or a restriction caused by something protruding into the air passage. As the air flows past the restriction, it creates a low pressure area and that is what sucks up the fuel under normal conditions. Did you use a gasket when you mounted the carburetor? If so, did you cut out the hole in the center of the gasket to let the air pass thru? If your ignition timing is remotely close, and you have good compression, then suck up a bit of fuel in an eye-dropper, remove the sparkplug, and squirt it into the cylinder, then quickly put the sparkplug back in, put the coil wire on, and spin the engine. If it doesn't at least "pop" or try to start, then the problem may very well be in your ignition system.---Brian
