the distilled water is interesting I had some and used it in a humidifier thinking it was good . Ruined the humidifier .
Data sheet - off the web:
https://www.chemicals.co.uk/uploads/documents/44 - 2654 - SDS11558.pdfhttps://www.answers.com/chemistry/Is_Distilled_water_corrosive
https://www.cheresources.com/invision/topic/15821-why-is-dimineralized-water-corrosive/Araboni:
Dimineralized Water is NOT corrosive. Let's agree on that fact. However, contaminated DM water IS corrosive - especially if contaminated with dissolved oxygen or carbon dioxide.
If oxygen is present, you get one form of corrosion: rust (or iron oxidation). If carbon dioxide is present, you get acidic attack on the steel with resulting acid etching of the steel. Both types are corrosive.
If your DM is stripped of all dissolved gases and is truly pure H2O, then you should have no corrosion. It is the contaminants that give problems - not the water.
https://www.corrosionpedia.com/definition/407/distilled-waterCorrosionpedia Explains Distilled Water
Raw water usually contains a number of microscopic contaminants, along with dissolved minerals, such as calcium and iron. These elements can be removed from water through boiling until water changes to steam; this process known as distillation. When the steam is allowed to cool down and condense into liquid, the resulting purified water is called distilled water.
When water is heated in a distiller, any dissolved solids, such as salt, bacteria, calcium or iron, remain solid while the pure water converts to a much lighter steam and is drawn out for condensation. This water should ideally be nothing but hydrogen and oxygen molecules, with a pH level of 7 and no additional gases, minerals or contaminants.
Since the minerals and ions typically found in tap water can be corrosive to internal engine components, distilled water is preferable to tap water for use in automotive cooling systems. Similarly, it is also used in model steam engine boilers and model engines of other types to prevent scale buildup.
Despite its benefits, distilled water is particularly corrosive. With no minerals to give the water pH balance, distilled water acts like a magnet, absorbing chemicals (phthalates and bisphenols) from plastics, nickel from stainless steel, aluminum from aluminum containers, and carbon dioxide from the air.
There is loads of information on the web... these are just a few postings.
I was also taught (by a water expert - supplying "pure water" for a laboratory system) - This water is more corrosive than regular tap water, so DON'T use it in car cooling systems - or anything similar - without corrosion inhibitors. He also tested and approved the water we mixed with Long-Life Coolant - to make the 50% mix for filling new cars. (Up to 1/2 million per year).
The phrase that hits me as obvious... (I'm sure I was taught this in School Chemistry at about the age of 11 or 12?):
"Despite its benefits, distilled water is particularly corrosive. " - Seems to sum it up?
