rolphill
Good news and bad news.
Good news, the firebox is done, straightforward and easy.
Bad-ish news. I finally got around to taking apart the steam engine I built a couple years ago. On the outside, it was filthy from sitting in the barn for two years. On the inside, it was nice and clean, no visible wear. Except...
The X rings on the piston valves were all torn up, even though I barely used it. Mostly on the side with the big hole for steam input. The small slots that went to the cylinder weren't so bad. I thought about converting it to slide valve, but that's almost as much work as building a whole new engine. Plus the port positions aren't ideal. After thinking about it for a while, I took apart an industrial compressed air spool valve, which is basically the exact same thing. On the inside bore, there are cavities with chamfered lead ins where all the ports are, so the o-rings never actually slide across edges. I'm going to try to replicate that in my piston valve before trying anything drastic.
Also, I'm out of x rings, so I'll have to get more and probably make more valves which isn't hard.
