Hi,
Got on with the first of the top fittings today. Very similar to making the bottom fitting other than starting at its hole end rather than the threaded end. Missing out some of the machining that has been coverd before.
Centre drill.
6.2mm hole 1mm deep for '0' ring seating.
4.8mm hole through to transverse holes for 7/32"x 40 TPI thread.
Tapping 7/32" thread.
Parting off.
Hole for gauge glass is drilled from this side as it has to be as concentric as possible with the thread.
Centre.
4.2mm hole through for gauge glass shoulder and threaded.
Dry assembly.
Broaching hole for gauge glass and showing over heated joint! Must do better.
Staring on top nut shouldered and threaded 7/32"x 40 TPI.
Checking fit.
Facing.
'0' ring fitted.
Assembled next top fitting will have a deeper recess for the '0' ring.
Screws were shortened in the lathe using a file.
Preliminary assembly of water gauge fittings on the boiler showing copper washers and sealant to be used. Copper distance washers could be used by themselves which was always the way but I think that the sealant reduces to chance of de-zincing.
Fittings sealed being checked using a gauge glass before the sealant goes off.
Fitting glass.
Finished?
Forgot to put the last photograph on PhotoBucket.
I will go and find it.
Regards Tony.
