I have now reached the point where l am able to run the Darj B class l am building. After various tribulations with the boiler(more of that later) the engine ran but was a very jerky and not continous in reverse. So back to the books, on reading l discovered that the return cranks on an outside admission system (slide valve) should be to the left of axle centre when the crank is at the bottom of it,s stroke, mine are to the right, if l were to change them it would no longer be prototypical. Drawings and photos clearly show the return cranks are the right of the axle centre. When l came to the books LBSC,s Model Locomotive Building the overall drawing of Tich at the front of the book shows the return crank to the right, later in the book in the construction bit it shows the crank to the left. A similar contradiction occurs in Martin Evans, book Manual of Model Steam Locomotive Construction. Now totally confused prefer it where l have got at it adds to the spindly appearance of the valve gear. Do l need to change it? Regards exairman
