Tony Bird
Senior Member
Hi,
Before starting on the burner I decided to tidy up what has been done so far and also fit some simple couplings to the buffer beams. The burner is completely new with a slightly smaller tank than the previous one. The construction is the same only having two filler tubes as Colin had designed. These tubes canl be used to empty the tank and an overflow is still fitted. The burner is designed to be easily and quickly removed to adjust its wicks, It is held in place with a screw through each frame going into a tube that goes through the burners tank. The front end of the burner is supported in a hole in the front stretcher cum draught/flame guard. Following some photographs of the progress. Tomorrow should see the burner finished.
Regards Tony.
Regards Tony.
