Vertical steam engine build
cheepo45
Delaware
I am working on the vertical engine from the Victorian Stationary Engines book by Stewart Hart (Excellent book by the way!)
The first part I made was the flywheel (I like flywheels!)
It started out as a 3/4" slice of 5"diameter brass that was given to me by a friend.
The Lathe work was first - face, O.D., trepann the center cutout and finish with boring bars.
Then I set it up on a fixture in the mill. The spokes were cut out using my Bridgeport Mill with a Prototrak CNC controller.
I then chamfered the spoke edges, flipped the fixture over and chamfered the other side.
It came out really well.
Scott
    2.3 MB
    2 MB
    1.8 MB
    1.5 MB
    1.5 MB
    2 MB
Scott
Very nice work!
Nice detail.
Keep it up!
Sid
The next part I have completed is the top plate.
Sorry, I don't have any in-process pictures, but the part came out great!
I will be painting this metallic grey soon to go with the rest of the engine.
Scott
I like the flywheel, and admire you skill using CNC. But I am a bit traditional in that I prefer to see a model made with HHC,.. I.E. "Human Hand Control. Probably because that's what I learned in the 1960s, before "C" was used for such things!
So I bought a brass casting of a similar flywheel. It looks quite authentic with the flaws and natural appearance of the casting. Hard to replicate with your "non-Victorian" machining.
Not a criticism, just a different Opinion.
But we'll done for doing the CNC!
I have a 1983 Bridgeport with a retrofit Edge controller from 2000.
I have been running Prototrak mills since 1997. They are perfect for modelmaking.
It's kind of a crossover machine - CNC on the X and Y axes only. the Z is fully manual
There is something to be said for manual machining. I worked with rotary tables and indexers, etc. for many years, and I do enjoy figuring out things the old way. Machinists from before CNC became prevalent have my deepest respect.
Scott
Metric ?
Send it back................
LOL, poking fun at my friend Graubele.........................
Nice work on the engine Scott.
I am following along.
Metric Victorian Engines? I usually do everything in multiples of 5/127th" or fractions of it.
Is the book including real drawings to make the thing?
Is the boiler a Yarrow type?
Hello Jojo
Do you mean the steam boiler in the picture from post #3?
No, that's not a Yarrow.
It's a very simple steam boiler that I designed and built myself around 2012,
with no complicated internals and a total volume of 2 liters.
But I don't want to hijack Scott's construction report here.
I only got involved because I have a similar machine like he is building and bought the book based on his recommendation.
