Upshur's opposed twin engine
Here you go Brian, that same assembly being rotated
Read the bottom right first to see what is going on with the right side cylinder then watch again to see how the rear one follows 360deg of CRANK rotation later. This is for the Bobcat based engine as I have the parts modeled. You can do the same with yours and then do it again with the Upshur arrangement and if you have it right will get the same results.
Watch it full siz eon Youtube.
two cams compared, see how the two inlets and th etwo outlets face the same way.
If your CAD allows you to set gear ratios and directions then just assemble these few parts and turn the crankshaft round and watch what the cams do.
Brian uses Solidworks which should have mates and motion capability as well as gear ratios. I have never seen him use that feature in any of his builds. (it is possible I missed a post or course)
I use Solidworks all the time when figuring out valve timing. I don't post about using it because there is nothing to see unless you have the program.
You can use screen captures and/or motion study video captures in Solidworks.
I use motion study a lot to verify that the parts fit.
If the parts don't fit, the engine and/or mating parts won't rotate in motion study.
One of the more useful engine design features I have ever seen.
That is good that SW can do it so you should be able to do as I have done and see how the timing works, saves having to keep pulling the engine apart. Look forward to seeing the running engine.
Not everyone has Alibre but the video and screen shots I post allows anyone to see how things should work so that is why I post it, often a picture/video is better than words.
Question of the day---What do you call this particular sort of spring clamp and where can I buy it to fit 1/4" and 3/8" gas lines. Preferably in Canada.
I'd also suggest you look at that cam you made a couple of days ago, looks nothing like the first pair you made, not sure what you have done, either wrong duration or a much larger nose radius which is likely to result in a lot less lift if you started with the same size material.
Originals
And this is the one you just made with the grub screws. You are going to have problems timing it with different cams
