A couple of twists of wire would do the job and look less cumbersome or bend your own from spring wire.
I thought I recalled Brian saying there was a hobby shop nearby. They should have tiny hose clamps, they use them a lot for Radio control stuff.A couple of twists of wire would do the job and look less cumbersome or bend your own from spring wire.
Amazon has about 5 lifetime supply for $10 of the flat spring clamps typical of fuel linesI don't like gear clamps!! On something big like a car radiator hose they are fine. On something as small as a model engine, not so much. I had hoped to get a smaller version of the spring clamp laying in the foreground, but couldn't find any in Barrie. I have just put the smallest gear clamps I could buy in town on the intake manifold tubes. Kind of ugly, but they will do for now.
You cold easily make some suitable gaskets from brass (I know you probably don't have copper) turning the ID and OD in the lathe then soften them by heating and quenching.Well. There ya go. And loctite is the answer?? (NOT)
The plugs don't really need to be tight. Use an O-ring under them to get you going until you can make some copper washers. Just a bit over finger tight is all you need with an O-ring.
I have made them from some brass tube and just parted them off in the lathe. I made several because I know that I will drop some.You cold easily make some suitable gaskets from brass (I know you probably don't have copper) turning the ID and OD in the lathe then soften them by heating and quenching.
Loctite is not the answer. (or JB weld for that matter!)![]()
