As per title really, whats the best way to time the hoglet?
Ive set the left piston (looking at it with the camshaft facing me) to TDC. Rotated it 90 degrees clockwise and set the inlet valve to be fully open. Does that sound about right?
Ive also seen a few hoglet with a carburettor that you pull and a spring then closes it. Are people using ones that come off nitro engines? I have made one myself following Brians plans but Im not sure if my tolerances are a bit tight as its quite stiff to operate.
