Opinions on how to approach making a casting for the Chenery Gnome Rotary will vary.
I can offer one way to do it.
A photo of what I think the casting would look like is at post #22 here:
https://www.homemodelenginemachinist.com/threads/les-chenery-rotary-engine-1-5.31718/page-2
Assuming the casting is laying flat on its back, with the crankshaft facing straight upwards:
It probably would be easier to split the pattern hozirontally at the centerline of the cylinders, but you can always use a follower board with a one-piece pattern.
I think I would use a 3-piece flask, and let the runner be in the lowest flask.
The runner would be horseshoe-shaped, with a vertical sprue at the center of the horseshoe.
Two long knife gates from the runner, one each side, into the bottom/side of the crankcase.
You could use spin traps at the ends of the runners if desired.
The core in the center would be round, with radial coreprints going out for the cylinder holes.
My 3D model machine is not set up at the moment, so I can't sketch it up.
Extend the bottom of the casting down to allow machining allowance, and to allow the gates to enter the mold cavity.
Then machine the gates off.
You could add a boss on the top of the casting to allow you to grip it, and then machine that boss off.
I would consider using a sodium-silicate bound mold for the cores and mold, since this part seems to be relatively small.
