Today I welded up one of the flywheel fans. Let me be the first to say its uglier than original sin!! However, I haven't done any clean up on it yet. I've welded it in all of the spots (4 per blade,) that I intended to. I didn't melt anything away, although I probably added three times as much filler rod as I needed to at every spot. There seems to be only micro-seconds between having the metal molten enough to 'merge' with the filler weld and so hot that you burn away the fan-blade. I tried it with a 1/16" tungsten and filler rod at 70 amps max and with 3/32" tungsten and filler rod at 115 amps max. I am dazzled by how quickly everything happens. Back in the day, I did a lot of oxy-acetylene welding, and since I controlled the torch, things only happened as fast as I wanted them to. With this TIG process, it keeps wanting to run away on me. It gets so hot, so quickly, and gets molten so quickly that I'm afraid I'm going to melt everything before I get a chance to add any filler rod. Next step will be to clean everything up and decide if I want to add any more weld anywhere.
