Go get yourself a cup of tea or one of your favorite cold 'soft drinks'
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
because this one is going to take some time. All of the steam engines I have made to date have always utilized a length of stainless steel rod for the piston/conrod or the piece has been a casting requiring one to either turn up some threads on the end or drill a set of holes for the later. Now, here, staring me in the face and laughing at me was a billet connecting rod that was in the shape of the ones you would see inside a automobile engine :-[. Egads! Well, with much trepidation and hand wringing (did I mention procrastination before ???) I began the journey, relying on much of what I have witnessed here on HMEM as a guiding light (Mom? is that really you??!!... No, ..*BELCH* it's just me, your imagination speaking to you, now continue) to fall back upon in my attempts to conquer this first time IC project. (whew, I'm glad of that but you really could use some Tic Tacs :big
To start off with, I flycut a couple of short lengths of aluminum bar that were a bit long, down to the necessary thickness. On the ends I did the usual layout and center pop of three locations. Two would become the holes for the clamping studs and the third was on the exact center of the piece and would be used to indicate the piece later on. The next step was to drill, counter drill and finally tap what would become the 'big end'.
This was easy enough until I realized in a brain fart that I had not counter drilled the first hole and had to go back and re-center the piece. I used the small ball end wiggler point to do this and after drilling, life was good once more.
Shown below is that central location I mentioned earlier being used to get the piece centered in the four jaw chuck in preparation for turning the outside diameter of the big end. These steps were all done prior to the end piece being sawn off.
After liberating the small, cap piece from the main bar both faces of the saw cut were faced and joined back together with 5-40 bolts for the remainder of the machining work.
This rather crude looking device (get yourself accustomed to them) is not an instrument of torture from the 16th century, although I suppose that if one were to close ones eyes and drift back to that period of time in France......... *AHEM* Oh, sorry. Now where was I, oh yes. What I reworked was a holding fixture from another build, it consisted of an aluminum disc that was screwed to the back of a piece of Oak with two rails spaced so that the conrod blank would just fit between them and then a set of holes drilled and tapped to receive clamping screws. I've said before, I don't have DRO in the shop, nor a large enough faceplate but brother, believe you me, when this is all over and I survive, I'm definitely going to have them as well as a rotary table!! *club* The prepared blank gets clamped into position and the whole thing is centered using the DI and wiggler routine and then the openings in each end of the conrod are drilled and then reamed to there specified sizes.
From here on, every step is a "mirror" image, that is what gets done to one side of the piece is duplicated on the reverse. I again went to the drawer of past used fixtures and found that with some minor modifications I could use this one to cut down the cheeks of the big end. The clamping button was made to the desired diameter so it was an easy task of advancing the cutter until it just nipped this piece and then using the micrometer stop, set the depth of cut, and after flipping the piece over on the jig and using the same dial settings, voila!, perfect symmetry at its finest.
Now just when you thought it couldn't get any crazier Rof}, I have one more for you, and then I promise that I'll stop. (no really :
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
) This jig is very similar to the previous one, but seeing as how I was going to be reducing the thickness of the rod some more, I did not want to chance it flexing and decided to go with a more conventional looking faceplate arrangement to 'neck down' the small end. Also, in keeping with my previous track record of not staying to plan convention, I used a cutter ground with a radius rather that a squarish looking section.
Once the edge-on profiles were to my satisfaction, I turned to the more conventional methods as seen here to shape the sides. The drawings do not call out any dimensions for the taper so I had to do some "cut and eyeball, adjust, and repeat" in order to achieve a pleasing line. I wound up using 3* but I think I would like to go down to 2.5* or even 2* if ever I pass this way again. To hold the blank I first set the vice at an angle to the table using a protractor and clamped a short sacrificial bar in its jaws. I had previously marked out, drilled and tapped holes to correspond with the center-to-center spacing of the conrod blank on the centerline of this plate. The hold down buttons were turned to the target sizes and brushed with layout dye. When the cutter advanced far enough on the final cut to just graze the Blue, that was far enough.
Man, nobody ever said this was going to be easy!!! When the dust all had settled and I was able to collect my thoughts again, I found that I did not like the rather square looking big end and set about to make it appear more scale-like. (are you beginning to see a pattern forming here? I do)
First it was to trim down the back side just a bit and then counterbore for the cap nuts.
This of course was done after I made up some threaded studs to take the place of the cap screws. Then, using some filing buttons to round over the end I was at last done.
I want to cut a scallop into the sides of the rod but am going to wait a few days and catch my breath. There was a post up here a few weeks ago about that very thing so I will attempt to search for it. And I have to press a bronze bushing into the small end. That is not really necessary according to the plans but I want to put one in anyway. Whew! Thats all for now, so far, so good. Thanks for looking.
BC1
Jim
