Yeah, yeah, "P", "Q", #9, #6, backwards, forwards, sideways, anyways, they all look the same after a while ;D. And no Dean, you may not have my hammer, it's mine so there
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
. Now on with the show. This is the beginning of the cam follower guide, it started out as a piece of square brass stock that I had in the drawer. I did this on the fly, measuring the dimensions as I went along rather than laying out cut lines etc., it seemed to work out well. Using a .250" cutter in the mill the contoured face was cut a bit overly long as I could come back and do the final sizing later.
Then the piece was milled down to required size
.... and then flipped 90* and sized to final dimension once more.
I then switched to a .125" cutter and proceeded to open out the center portion of the piece, this would become the slot for the cam follower/latch to slide in. The bottom of this slot gets undercut in order to reduce the frictional losses. I'm not certain at this point that this step is necessary but the drawings called for it and who am I to argue the point. (don't go there
![Stick Out Tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
After all of that, I cut the piece off the bar with a hacksaw and set the piece back into the vice to perform the final sizing as shown below. If you look closely you can see that I used a .250" cutter blank in the slot to keep the sides of the piece from being deformed during this operation, it fit very nicely in the opening with no perceivable side play.
Now this is where it gets a bit 'strange'. :
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Usually I use the barbaric method of laying out and center popping hole locations but this time I got lazy and did not really feel like messing around with that whole thing so I decided to use an even cruder means of centering the hole and that was to turn a bit of brass down to a diameter that would be a snug fit between the webs of the piece and drill a through hole in it using the size called out in the drawings for the screw clearance hole. With this 'jig' installled it assured that the location was central to the sides. In thinking back now, I got lucky in that I was extremely accurate with the previous machining operations and the hole came out just a few thousandths from its exact specified location. Whew!
![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
The final step was to countersink the hole. I know, I got some chatter marks, but they will be covered by the screw head. For both of these last two operations I held the part in my drill vice but forgot to snap photos during the procedure so these are 'staged' after the fact.
And the completed part.
I'm thinking that things will begin to slow down just a bit from here on as I require some additional pieces of stock (for the crankshaft and the flywheels) and do not have the spare funds available for their purchase. In the meantime, I'll keep scavenging and making the parts that I can from my stash. So far, so good. *I think* ???
BC1
Jim
