You are right Arnold, the shipping for either of us would be horrendous th_confused0052 to say the very least. Anyway, getting on with it, I did some what I term minor apprentice type work this past week. I elected to work on making the regulator bobbin and I have to admit it, it was just a bit of a whore :hDe: and it took me three attempts to finally get a finished product that was accceptable. Looking through my materials drawer I found the remains of some sort of lathe spindle adapter I had begun who knows how many aeons ago (long time) and figured that I most likely would never finish it as I had forgotten even what I had wanted to do in the first place with it ???. So I chucked the bar up in the three jaw and began what I thought was going to be an easy part to make. Remember a while ago when I said none of them are ever easy? Well that statement could not have been any more true than here. After turning the piece to the required finish diameter I thought "I'll just use my trusty parting tool to machine the grooves and I'll be done in no time". In a pigs...*ahem* ... eye.
oh: I very carefully took the cutter tool over to the grinder and gave it a good facing, taking extra pains to get a nice flat, square face and used a stone to make nice little radii on the corners, not a lot, but enough to cut the sharp edges. Back it the lathe and after setting up I quickly found that no matter what I did I could not get the tool to cut worth a darn th_wtf1. I tried changing the center height, as well as grinding a different rake to the tip and no matter what I did it still would not cut decent. OK. Plan "B". I decided to grind a square tool bit to profile and do it that way. Well that was a bit better but not by much and just when I thought I was done with the first groove, the cutter snapped off
. Jees, what a real pig this is turning out to be th_bs. TIME OUT!!! I decided to postpone this event until I could re-collect my wits and trudged upstairs having been defeated in this round. A few days later, I returned to the scene of the crime and removed that Hellish piece of bar from the chuck and banished it to the trash receptacle for eternity. Once again I sat over my materials drawer and lo and behold, there was this nice bright and shiny new piece of stainless steel that my friend had given to me peeking out from behind some lengths of brass. He said it had been in with some of his Father's stuff and he had been a machinist by trade, working on food processing machines. It was a bit larger in diameter than needed but that would be OK, I had a plan. Once again I ground a cutter blank into the desired shape and made the width of the 'blade' narrower than the groove I wanted to form. This was part of my plan. If this worked, I would part to depth and then move over incrementally until I hit my target width. EUREKA!! :bow:, this time the cutter groaned just a bit but stood its ground and in a few minutes I had my first groove cut.
Now to sneak up on my target width of .095". Dial calipers are OK for most things and even when measuring small slots or grooves I find them relatively accurate, however, this time it had to be spot on so I used a number drill bit shank as my guide.
BINGO!! Right on the money! Yes Elizabeth there is a Santa Clause Thm:
Now, to move the carriage over and do it again. Oh, joy, we have to do it again? (you can probably tell I was not having a great deal of fun at that time) To do this I relied upon my micrometer stop that do so often use and merely dialed it over the required amount and locked it down. The second groove seemed to cut a but better than the first but who knows.
Using and old brown stuff turners trick I used a set of manual outside calipers to hit my target minor diameter. It works and the depth really isn't that critical as long as it isn't too deep.
Again, using the micrometer stop settings and the number drill as a guide the second groove was finally arrived at. THAT was the hardest part in all of this, the remainder was all down hill from this point. Yipee!
After facing the exposed side down to size the piece was then center drilled, incrementally drilled to just under finish size and then finish reamered. After which I used a die makers burr my Dad had given to me years ago to break the sharp edges of the hole.
It was now time for some 'character building', that is, the use of a hacksaw to liberate the part from the parent stock. Rof} (right Dean?
) With the piece now in my hand, I made up a quick and dirty collet by boring a short piece of Alie that I had in the scrap drawer. The 'tube' as it were, was a blind bottomed hole that allowed a place for the part to be seated against while final facing.
Finally the piece was finished. Hallelujah :bow: My first problems I encountered on the making of this piece early on was due to the material I was attempting to use was of unknown alloy. It was extremely gnarly and tough. I probably could have used it if I took the time to explore different spindle speed rated and all of that but to me, the piece wasn't worth that kind of effort, I wasted enough time doing what I did originally using that bar, whatever it was. I've never really turned much stainless but found that this alloy was quite a pleasure to work. It seemed to cut nicely albeit for a few harder spots but overall I think I would like to do some more work with it.
I've been procrastinating making a couple of pieces and am quickly running out of excuses not to do them (governor weight arms and the regulator arm) both odd shaped pieces that call out for a .... you guessed it ... rotary table. Whew boy. Am I ever going to catch a break? NEVAH!!!! We'll see.
so far so good.
BC1
Jim
