Team Build 8
Hey, now that is starting to look like an engine :)
Pat, I think the missing part you referred to is the same as the "Grounding Link Elbow Joint Bushing", Sheet 15, A4, which was in Brian's parts. I have fitted it to the beam, in the "Beam Parallel Links", and the "Grounding Links" hang from it.
Chuck
Chuck,
The part I'm referring to is like the part on page 15 zone A4 ... but shorten to about .508". That one (.508") holds up the Piston Rod. That's the one we have to make ourselves ... I believe.
Thanks for checking,
Pat H.
Pat H.
I'm not following you Pat. Sheet 15 A4 would be one of the parts I sent out. Page 15 of the PDF file zone A4 is the piston rod.
Brian,
Thanks for checking in.
1st off ... I have page 13 zone A4 for the Piston Rod. :confused:
Actually I'm referring to the part that holds up the piston rod. Yes, you did send out Item 33 (page 15 zone A4) ... nicely done! The part drawing that is missing is like that one but shorter ... length should be about .508".
I was pointing out we may have to make that ourselves, because I could not find a drawing for it. :eek:
Pat H.
Hi Team 8,
Great build!Cant wait to see them running.
When do you think the auction will take place?I would like to bid on it.Will it be a kit or a complete engine?
I would like to join team and build a engine.(Team Build 9? Anyone?)
This whole thread was just a wonderful read.
Thanks guys.
Tim
Thanks Tim Problably Next Fall for us in the north , but a team can be started anytime just put the word out and see what kind of responce you get. As far as the auction ' I do not know , Dale
Brian,
Pat H.
Ahh, I understand now. You meant that there is a part that looks like item 33, but shorter that isn't in the plans.
My head was jut being thicker than normal. It is perfectly clear to me now :)
I received Chris' parts today and of course I'm trying to assemble them. I noticed what I think is a dimention problem, which brought up a couple more questions. Sheet 14, Valve Link Bellcrank and Bellcrank Mounting Post. The BellCrank mounts on the mounting post which mounts to the Steam Chest Cover, right? If so, the mounting hole in the Bellcrank is too small. The sholder on the mounting post is .141" and the hole in the belcrank is .125".
I was a pencil and paper or ink and velum draftsman for a while some 44 years ago, but I don't recall a drafting symbol that looked like an upside down pine tree! For example, on sheet 14, on the drawing of the valve link rod, there is a dimention at the right end, that is .087 preceded by a o with a slash which I construe to mean diameter, followed by the pine tree symbol and 0.125 The latter is what I don't understand. Is it something new in CAD? Does it mean depth?
If anyone has these parts assembled and can post a picture, I would appreciate it.
Chuck
Chuck
Chuck
Chuck
If I understand you correctly ... the drawing is correct. The Valve Link Bellcrank mounting hole (.125") is suppose to stop at the .141" diameter lip. That leaves a gap between the Bellcrank surface and the Hex portion of the Mounting Post. This gap is needed so the Valve Link Rod can fit between the two. Take a look at post #288. There is a SW rendering that shows the placement of the Valve Link Rod. Look at post 260 there is a short U tube that also may help.
I could make another better view if needed.
The upside down tree is depth ... don't know it is used in this drawing since it is a thru hole. :D
Pat H.
I must be thick, 'cause I don't see it! Can you do an exploded view or maybe an end view from the cylinder end?
I'm going out to the cooollldd workshop to see if I can come up with some 1/8" brass to make the piston rod hanger that's missing. Would aluminum do? I think I have some 1/8" aluminum rod.
Chuck
Chuck,
I will try and get something up this pm. but it might be a bit late. ;)
Brass is much better :) but I suppose Aluminum would do. But then again I'd rather send you some. :cool:
Pat H.
Pat,
I found some 1/8" brazing rod I think, and made the missing part. It's kinda red looking compared to brass.
I now have the piston rod hung from the beam!
Can't wait to get Mike and Mike's parts(where have I heard that before?).
Chuck
Chuck,
Take a look at these views:
Pat H.
Hey pat great job I have been holding off on that part till I got a better idea how it goes together.
Chuck,
Don't know. I went to a different computer and used Internet Explorer ... everything came up fine.
Have you been to my web site before?
Can you view other images ... say post 400?
Pat H.
