Brian, I recall the posting about turning the valve stems down in steps, but decided that if I used 1/8" drill rod with larger pieces soldered on it might work out better. I have a nice fit between the reamed hole and the drill rod, so off to a good start already. Hopefully my ignition and spark plug will arrive next week, as I want to get it running before starting on the governor.
Paul.
Brian, drill rod, or what we call silver steel over here, is spot on on size. I measured the valve stems as best I could and they are 0.12525". I used a new 1/8" reamer in the holes and the rod slides in nicely.
Paul.
Swifty--Great Progress!!! I am pleased to see another build of this neat engine. I hope you have fun, and come up with a good runner. ---Brian
Glad that you have decided to jump in Gus, everyone needs challenges to make life interesting. In order to gain skills you need to get out of your comfort zone and try something a bit more advanced. You have already built an IC engine, so you are ahead of me there.
Just take things slowly and don't rush, this is how mistakes are made. However if you do make a mistake, learn something from it and move on. Before you machine something, go through the steps in your mind before starting, and then go for it. If you are going to use metric size silver steel, just make sure that you change the drawings where necessary, I used 10mm instead of 3/8" for the main axle and therefor had to change hole sizes.
Good luck with your build.
Paul.
Swifty--Great progress. You are now far out ahead of the pack. I think my one Englishman has stalled out due to lack of equipment, and the other one is still finishing another engine which he is posting on this forum. Luc the Canadian has been pulled off his build with some other "real" work. I've lost track of my other two Australians at the moment, and the chap in California doesn't appear to have started his build. Gus, we are watching for you to start your build.----Brian
