Johnny1320, the valve clearance is set when I built the motor, there is about 0.1mm clearance. If the valves bed in a bit, I will have to tweak the length of the valve stem to reset the clearance.
Brian, I will still have to play with the carb a bit yet, if I have it wide open and adjust the needle so it gets maximum revs, it doesn't run so well on idle, I haven't touched the idle jet screw yet, maybe that will fix it. The idle screw jet only appears to let in a bit more air in through the small hole, surely I only have to adjust the idle stop to get the same result, maybe I'm not looking at it correctly, still it's early days yet.
Paul.
