Thanks Ray, but when I enlarged the label picture I could not read what it says. Maybe as you are closer than my poor eyes you can type the volts and amps it says? All I could get was a blur. - possibly DC 5.4V and 1.5A ??? But I did see " 2 phase" clearly, but not the "step" bit.
My worry is that if it is rated for less than 50V, you really should not try and run it over 50V. (Based on my experience of 12V car wiring being designed to resist a voltage "spike" of 50V without puncturing). The lacquer on the windings is very likely to fail due to switching voltage "spikes" if running at anything over 4 times the rated voltage - in my manufacturing experience... After the lacquer has failed, the windings will rapidly - usually catastrophically - fail.
So the question may be: How slow can you run it to get the voltage (around 5 volts) for USB charging? - put the AC output across a diode bridge and measure the DC voltage...
