Small V8
The pump will pull water from the bottom of the radiator and push it into the odd bank of cylinders. It will cross in the back thru the bellhousing adapter and come back thru the even bank of cylinders. Then water will be forced up thru the head, into the manifold, and out the water neck and back into the radiator.
Not much to report. I made a test rod to check my rod length. The rods are 1.350 C to C so I made a piece with the 2 holes at 1.350. Then the piece was milled to at least 1/2 way thru the holes and cleared to miss the cylinder walls. The rod was set on the crankshaft and a wrist pin was inserted into a piston. The piston was then set into the cylinder and the piston brought to top dead center.
Cyl #1 +.009 ( piston out of the bore .009)
Cyl #7 +.007
Cyl #2 +.012
Cyl #8 +.010
So with this data I can see that my decks from front to back are less than .003 out and the difference between the 2 decks are .003 out. I'll take that any day.I am going to make my rods 1.340 and if the #2 piston sticks out .002, no harm done.
Maybe this week will be spent making rods and bearings.
Lookn' good. What compression ratio you shooting for? Gonna have it running by NAMES?
Hi Steve,
Thanks for your informations about the water... :)
Which fuel do you want to use?
To use gasoline, the ratio would be higher, right?
Alexandre
Thats certainly very close and tight tolerances, but dont rule out the crankpins being a little off. Thats traditionally (full size) where the largest part of the compression ratio variance comes from. Even full size, them crankshafts are hard. :)
You can make each rod a custom length fit to each cylinder on those "absolutely positively gotta have every last horsepower" type of motors as well. But here I am giving away my drag racing secrets. :)
That's why I check with a test rod. This way the actual length from the crankshaft to the deck is factored in. .003 won't affect much of anything. Peewee was .015 from the shortest to the longest so I split the differance and no way can anybody tell. I'll take .003 any day!!
Interesting stuff. I've almost got my crank beded. I'm gonna check the crank once its in place just to see how close eact throw is. If its a long way off I keep it to myself, otherwise I'll brag about it. :)
Still trying to get over this cold so I figured, work on something easy. My friend went to the local cabinet shop and asked about some corian counter top material. When the guy found out what it was for he gave up a piece that was cut out to install the sink. This piece was plenty big enough for me to get 2 pieces 7-1/2 X 12 for the display bases. After drilling the holes that will mount the engine, gas tank, and radiator, I used a corner rounding bit to ease the top corners. The big holes are threaded and will allow me to secure the 2 pipe stands that will pass the sensor wire and coil wire from the ignition.
I like this stuff for 2 reasons. First it resists gas and oil very well, and second, because it looks like a miniature terrazzo floor.
Outstanding Steve!!!!!
gbritnell
Very nice indeed Steve. Well done.
The "I need it for my Miniature V8" line can be quite a persuasion tool when it comes to getting what you want. :big:
Kel
GDay All,
Steve, what an excellent job you have done! :bow: :bow: :bow:
I am totally jealous at this point because I designed a very similar engine in Autodesk Inventor so time ago that I am planning to build.
Your bore and stroke dimensions are close to mine as well .... bah humbug!
I wish you well with the project and I have read all from the first post to this. It has been a very interesting journey so far and I'm just as eager as everyone else to see the completed engine up and running. I don't think you will have too many problems getting it running, if the quality of your work is any indication.
It is also encouraging to know that my own design is feasible and machinable even though I'm still collecting tooling and materials, not to mention skills, I figure, if you can do it so can I .... maybe .... lol
If you end up offering plans for this engine, please put my name on the list :big:
Looking forward to the next chapter, keep 'em coming! :big:
Thanks for sharing!
trumpy81 said:
I am totally jealous at this point because I designed a very similar engine in Autodesk Inventor so time ago that I am planning to build. Your bore and stroke dimensions are close to mine as well .
I would like to see some of your models someday to see how other people think. I have another club member who has a V8 of this size running. Jim Peters "Victory V8" is almost exactly the same dimensions. It's great to see how he did some things and find myself wishing I did mine that way. Some things I like my way better. I think looking at others methods can make my future designs better. I don't mind sharing my methods if they will help make things better for someone else.
Cheers!!
Thanks for the kind words. I'm finding tough though to work with the engine setting around the shop cuz all I do is play with it. I'm gonna have to move it to the basement or somewhere so I can get some other stuff done. I intended this post to be longer but I'm breaking it off early so I can start the v8...again. :)
Thats what were all here for, hopefully to give as well as take!
I found out your club meetings are the same night as my radio club, which puts me at hazel park elementary school. What time do your meetings usually wrap up?
Sounds good, will definately have to do some planning, and hope google maps doesnt re-order the lettering on the campus. :) I was afraid if I showed up and had to ask, nobody would know what the S building was.
