Single Cylinder Opposed 2 Piston Engine
Weirsdale, Florida
I was surfing the internet and this drawing showed up and cough my eye.
It is a 1900 Gobron-Brillié opposed-piston engine.
It is a 2 cycle 2 cylinder 4 piston opposed engine.
I have only been able to find 4 drawings of the engine and almost no technical data so a picture is worth...
I will try to build a single cylinder 2 piston 4 cycle opposed piston engine of similar design.
I have already built a 2 crankshaft 2 piston opposed single cylinder chain drive engine that runs just fine. So I have high confidence.
I usually start by building the crankshaft of the model first and then make the engine block fit the crank. I had to order the ball bearings for the crankshaft and I wanted to get started so I drew this up for reference.
I marked out the lines on a previously sized block of aluminum.
Milling out the parts that don't look like an engine.
Milling the connecting rod relief sections.
And the results so far.
Thanks for looking
Ray
I am slowly building an single cylinder opposed piston two stroke diesel with side pull rods for the top piston.
I have question about your plans to make a single cylinder version of the Gobron-Brillié. As I see it the two pistons stop the top yoke from twisting, if you only have one piston it may tend to twist. This may not be a problem but I thought I would raise it. On the engine I am building the top yoke is guided by a square scavenge piston.
Roger you are correct and I haven't worked out just how I will address that problem yet. I will be making my cylinder longer than the cross arm travel with a longer slot to capture the twisting and turning forces through out its travel. There will probably need to be guides of some kind on each side of the cylinder also.
I had already milled the pieces for the crankshaft a few days back and was waiting for the ball bearings to come in. Well they got here late yesterday so today after mowing the grass I assembled the crank. The bearing pairs are visible in the two wider sections.
The two outer guide rods have been removed and after a couple of hours I will install the rod journals. Now the glue up will sit over night and then tomorrow the holes for the tapered pins will be drilled and pins installed.
Thanks for looking
Ray
This is a big deal! A home effort on a design almost lost to the ages. These opposed twin piston cylinders are showing up again in contemporary talk and articles for automobile power by specific output, economy, weight and component part reduction. Haven't seen type as a model project before.......you bring something new to the forum! .Dave.
Thanks for looking
Ray
Interesting project 👍👍👍
Please update ....
The Kansas City Haypress engine
Chuck I looked it up and found a wealth of information. Thank you
Drilled, reamed, and installed the tapered pins and gave it a paint job.
The paint isn't very dry but I had to see if the crank would fit the block.
It fits just fine.
Cut out 4 main bearing caps for tomorrow.
Thanks for looking
Ray
Ray, I searched the USPTO and WIPO sites for any patent refs and didn't find any for that engine type in that era, although I found plenty of patents with Gustav Gobron as the inventor. He was a very busy guy!
Lloyd
He definitely was and after the partners split up he built the first automobile to break 100 miles per hour.
I got the main bearing caps installed and numbered so I won't get them mixed up.
Over to the lathe with a drill bit first to get a large enough hole for the boring bar. My stack up looks precarious but it did work.
Line boring to just under the size of the bearings. I will finish with an adjustable reamer on the bench.
Thanks for looking
Ray
Ray, Is that line boring bar just a steel rod with a cross-hole for a hand-ground bit? And a center in the tailstock to stabilize the long end of the bar? how do you keep the vibration out of it?
Thanks very much, Lloyd.
That's exactly what it is and it doesn't work too well as it is only 1/2" rod. That's why I finish them by hand later but it does get close.
Ray
...............I wrote this yesterday and forgot to post it, so it might seem out of sequence..............
OK, I am a little relieved. The magic bullet is a secondary finishing operation, not some super stiff solid carbide rod with an integral boring and reamer, or some other secret mo-jo.
Nicely done 👍 👍
I am interested in your use of ball races for the main bearings in a built up crankshaft but conventional split bearings for the big ends.
