Rocket Man
- Nov 4, 2011
- 242
- 122
I'm probably telling people how to suck eggs But!!.
I had to teach our mechanical workshop guys how to silver solder. They said silver solder didn't work.
They had things clean enough
They had plenty of the correct flux
they had plenty of heat (oxy Acetylene)
But joints didn't run and leaked.
I observed how they soldered and it was obvious to me what was wrong.
1./ they overheated the joint by applying direct flame to the solder area -- the flame should be near but not direct
2./ The flame on the oxy Actylene was set at neutral not carburising ie long feathers , long cone, this is the most important factor. One must keep oxygen away from the joint so that it tins properly and the silver solder components are not themselves oxidised
The boiling point of Cadmium is 1412-F
This is true of the pure substance, but alloying can significantly change the boiling points of the constituents.
You won't be able to find out if Cadmium's boiling point increases or decreases in Silver because that's not what happens. For example distilling alcohol from water happens at the boiling point of alcohol, has nothing to do with the boiling point of water, or the boiling point of anything else that you might have alcohol dissolved in.
