Mike,
I think your decimal point is in the wrong place! As for leaks, two thoughts come to mind. the first is to use silver solder paste as a preparatory 'tinning' before actually sealing the joint. 'Tinning' does help and if you are brave and careful enough, removal of the dross can be achieved with a wiping cloth on. Your initial offering should leave everything bright and shiny in preparation for adding to equally important ring of solder. OK, I would use a long stick dabbed iin flux with a bend it to avoid poking my eye out but a ring of solder held by molten clear flux is the beginner's way. You need a steady circular motion rather - dabbing it here, dabbing it there approach. the heat around a tube or stay must be EVEN.
Ken should read the foregoing too!
My dear old father who could barely read and write would tackle a full size locomotive boiler and 'raise the dottle' from out of the weld. This is an old Northumbrian or Tyneside expression about the filthy residue left in a smoker's tobacco pipe and a weld if not scrupulously prepared will have the leaking mentioned caused by dirty inclusions. I'm not going to give a lecture on how to do it suffice to say that this isn't a dirty oily corroded lot of old steel piping and so on.
After all, EVERYTHING should come out clinically clean of a pickle bath ideally of dilute sulphuric acid.
