Hi,BUT the end plates do not work at 1/16in thick.
Thanks for the calculations. I guess I will have to buy a 3mm copper plate and form end plates.
One more thing to learn.
Nikhil
Nikhil and Steam,Hello,
I am going through other sites on internet for information.
What I could gleen from them is " A coal fired boiler produces a hot Sulphur bearing atmosphere that destroys joints made with copper phosphorus alloys.".
So I think phoscopper rods are not used on steam locomotive boilers nowadays.
I looked up the link and it cannot be delivered to India. I will look for other source for this book.
NikhilView attachment 149781
Hi Steam,Hi Nikhil.
A quick calculation of the 2 1/2 in tube - with penetrations - and the boiler - except for end plates should be just OK for NWP = 3 bar (45psi).
They must be at least 1/8in thick.
Sorry, but that is what the numbers say.
That is good to know. Thank you.Hi Lloyd.
I use information from old versions of ASME along with information that Kozo Hiraoka presents in his interpretation of the ASME regs for model boiler design in the US of A.
Hi,What PM engines are you steaming?
Property | Minimum Value (S.I.) | Maximum Value (S.I.) | Units (S.I.) | Minimum Value (Imp.) | Maximum Value (Imp.) | Units (Imp.) |
Compressive Strength | 45 | 330 | MPa | 6.5267 | 47.8625 | ksi |
Tensile Strength | 210 | 390 | MPa | 30.4579 | 56.5647 | ksi |
snip ...............Lloyd, Nikhil, Try this, if it will attach? - Just some pertinent notes from Experts. Not the latest, but close.
ASME-II-PART-D-METRIC-2019-www.fouladline.com........................
I agree 100%. It is very good practice to build a "safe" failure point into any type of pressure vessel. A pressure relief valve, an over-pressure plug, an o-ring installed with excessive clearances, etc, etc. A failure in a hydraulic system will normally just cause an oily mess, but the kinetic energy stored in a boiler or air reservoir is pretty scary. As Zeb said, if previous builders took the time to show their embarrassing mistakes, we might as well learn from them.Something I see interesting from a high level risk analysis perspective. If the greatest variable in a newbie build is the solder joint quality, it seems like having a wall on the thin side would tip the operator of an impending failure. This would be as opposed to having everything overly built and having a joint fail catastrophically. Those very handy empirical tests someone made showed excessive bulging before any type of failure occurred.
I've spent a lot of extra time making sure my engines run at very low pressure, with some compromises on tolerances. I like the boiler build videos above because she shows how things didn't go quite right. I would have made worse mistakes had I not watched it, as most people only show the best of their work.
No apology necessary. IN our "permissive" society, it is becoming to the point that a paper cut will require an ambulance to the hospital, a fart in church will require a city wide emergency shutdown. It's good that covers are required on gears, belts and other dangerous, open points that can pull clothing or jewelry into them and hamburgurize a person but it might be just as well to teach people that they are NOT made of steel, we are not supermen.Apologies for not reading all of this post but to see 1/8" thick copper quoted for boiler end plates on what amounts to a tiny boiler working at almost no pressure (45 psi) as overkill .
Too much negativity can put newcomers off a very rewarding and enjoyable hobby.
The casting of metal and the use of machine tools is no more dangerous than driving a motor vehicle , with the obvious proviso that you take care and understand what you are doing.
I would bet that more people are hurt in the kitchen than in the workshop but do we really need to tell people to be careful with knives or hot fat ?
I quite agree with youApologies for not reading all of this post but to see 1/8" thick copper quoted for boiler end plates on what amounts to a tiny boiler working at almost no pressure (45 psi) as overkill .
