Okay, next problem...
I connected the 110V input and plugged her in.
As the manual states the display will flash the input voltage, which says 110V and then the display
defaults to the frequency command value of 05.0.
So this is all good.
Then i connect the motor, which has 3 black wires and one ground/earth wire.
Not too sure if the 3 black wires need to go in a specific order or not?
Kind of hard to tell when they are the same colour...
Turning on the VFD again it runs through the same steps above and it flashes on 05.0 as it should.
The next instruction says to test motor without load.
So it does not have the belt on it, just the pulley.
Press the run key and i get an error LVC, which according to the manual is Undervoltage During Operation.
And then the GFCI trips.
The manual says the causes are:
1- Input voltage too low
2- Input voltage varies too widely.
One last thing i did try was to remove the 220V motor leads and push the RUN button on the VFD.
Works without any issues and i can change the frequency.
Do you think there is something wrong with the motor?
This is a pic of the wiring of the motor. It is wired the same as the left hand side.
Any ideas on what i could do to rectify this situation??
Andrew
