Richard, in my first post I wrote :-
"A BV20BL Ø220mm (over bed) x 520mm Chinese Lathe supplied under a local brand name. I have no idea who the Chinese manufacturer is or what other brand names it goes under – if you recognize it under other brand names or suppliers please let me know. "
It is dated 2016-1 Serial No 160103 - I bought it in new August 2016 from a local machine tool dealer "Adendorff" under their brand name "Mac-Africa" but their stock-in-trade is typically from the East - no other clues whatsoever - If anyone recognizes this as some other brand - let me know please.
The machine is a mixture of well made to downright awful - most of the latent problems I have fixed or improved - these are the list of changes made to date :-
Some Other Problems / Changes / Improvements.
In all I made the following changes to the lathe :-
1) Rewind motor to three phase.
2) Add VFD drive.
3) Add tachometer display.
4) Change ratios and “V” belt to Synchroflex T5 belt.
5) Speed change potentiometer for VFD.
6) Kipp – quick release handle for tailstock.
7) Kipp – quick release handle for carriage lock.
8) Tailstock quill – overtravel warning line.
9) Cross axis grubscrews as anti-twist for MT2 tang.
10) Spare axles for mounting changegears.
11) Knob for opening door (and hanging dustcoat).
12) Door securing bolt replaced with NiB magnet to keep door closed.
13) Oil change / Sight Glass improvement.
14) The chuck was held on with cap screws in counter-bores – nearly impossible to get out with a “short” Allen Key and immensely time consuming – so I replaced them with Hex shoulder screws.
Just a threaded bush on a hex bolt – you can imagine how horrid it was with cap screws. Much easier with a 13mm AF spanner than a sawed off 6mm Allen key.
All my chucks have had their adaptor flanges turned whilst reverse mounted –
in-situ on to another bar turned in another mounted chuck to ensure closest possible concentricity and trueness. Thereafter they were clocked for the best repeatable concentricity (one of three possible positions) and stamped with the alignment dots indicated.
Even the 4-jaws are marked because I might remove the chuck to my mill or rotary table and then return to the lathe – always a good idea to put it back the same way it came off.
Hope this thread has been of some help or inspiration to improving your equipment.
Regards, Ken
