hi friends
unfortunately I'm here only to report that all my attempts to get the engine running are miserably failed :-
as I mentioned in another post, I was unable to solve the problem with the TIM-6 ignition system, probably I damaged the coil leaving the system in an 'open' state (or whatever is called: as when the breacker points are open) and I never saw it working
so I bought an ignition system from Apache, a CDI system this time
it costs less than the TIM-6 + coil, and it worked immediately
the spark, also with the plug that I built by myself, was nice and strong
at this point I was enough optimist and I started to believe that a running engine was near to be seen
I spent several time to check the timing of the engine, a very critical point for the designer J. Ridders
but today I surrendered myself: I'm not able to get this engine to run
so I declare finished this build, and I enumerate it as a complete failure
it was fun to build anyway, and surely I learned a lot, but it doesn't run :-
here there are the pics of my last attempts, today afternoon:
now I will spent some time in the shop to make tools and reorganize the shop, and after that I will start the build of a simple IC engine (plans by Ron's modelenginenews.org)
probably the Scuderi was not the ideal choice for my first IC engine: another lesson learned, be humble, be humble, be humble and go ahead step by step![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![timing.jpg](https://proxy.imagearchive.com/bb8/bb85b0f9127f952c7c8ad6f36d9e6d70.jpg)
![end1.jpg](https://proxy.imagearchive.com/2f9/2f9ff95566871d967b86a5f56a9addeb.jpg)
![end2.jpg](https://proxy.imagearchive.com/e03/e03f719d0ff584acdb3026687f71eb4d.jpg)
![end3.jpg](https://proxy.imagearchive.com/81e/81e0780e899301dea8df30c1ca1459e9.jpg)
