I need to make a new draw bar for my mill and it is 1/2x13 unc. I would like to screwcut one on the lathe and found a table in L H Spareys book that shows for an 8tpi leadscrew I should use a 40 tooth driving a 65 tooth gear.
In the Myford book and inside the gear cover there is no mention of being able to cut 13tpi.
As I understand it Mr Sparey says the driver and the driven can be joined by any one gear and the ratio will not be changed. At first I thought that was why myford didnt list it as there appeared no gear would fit between the two. Then I noticed that the twin slot arrangement for intermediate gears was able to move round a bit. After fiddling I have a 40 tooth on the headstock driving a 45 that is driving the 65 on the leadscrew.
To my limited understanding that should work,or am I missing something?
Peter ???
Peter ???
