- Dec 31, 2010
- 820
- 220
I've been busy trying a few things. All of them failures. I tried a slightly modified version of the book carburetor. Conclusion - complete junk. I should have used the time to build the one Gordon presented a few posts back. The book carb doesn't have a venturi so the moving air does not create a vacuum with which to suck in fuel through the orifice. The air just knocks fuel off the needle and orifice in hopes it will be vapourized into the air stream. I blew some air through the finished carb and it actually pushed fuel back out the fuel delivery hose.
SO I made an adapter for a spare carb I have for my Howell V4 / V8 engine. That carb makes a spray of fuel as nice as a spray gun when you blow air through it and it is small and has a throttle.
Still no luck getting the engine to run.
Then after observing the motion of things again in my CAD program I had a revelation.
If the engine does not fire, then when the right piston goes through it's power stroke where the gasses are supposed to be expanding, instead (because it didn't fire) there is a huge vacuum created in the cylinder. More than the amount of volume compressed because the right piston moves very quickly to the right.
I always wondered why there seemed to be a pretty strong vacuum on the carburetor - much more than could be explained by the fairly short and relatively slow intake stroke.
What I think is happening is that the strong vacuum created in the cylinder by not firing is pulling fuel/air in through the carb when the intake port is uncovered. The vacuum is relieved but the fake charge is quickly pushed out the exhaust when the left piston follows along in the exhaust stroke.
I think this was pretty obvious when I looked at the intake valve popping open. It had a huge excursion - almost the full 0.1" limit of the spring. I would have expected it to barely open being self regulating.
So I think there is a fundamental problem with having two atmospheric valves especially on this engine.
So you might ask why doesn't a normal (four stroke) engine have a problem with vacuum in the cylinder when it does not fire. On a four stroke engine with cam actuated valves, the vacuum in the cylinder cannot open the intake valve so the vacuum persists until the the exhaust valve opens.
On a two stroke engine if it does not fire then the vacuum might help bring in the new charge or at least the fuel is coming is anyway by it's normal action of pressurized crankcase. And it's the compression stroke that follows. With this engine the intake stroke follows and it is being messed up by the missed power / exhaust stroke.
Gordon I believe you observed fuel dripping out your exhaust port. This may explain that. i.e the fuel is being sucked in and immediately blown out the exhaust port. I have a similar problem.
I think you've been lucky that the intake stroke actually pulled in some new charge or there was enough left around after the failed exhaust stroke to get it to run.
I'll admit that if it does fire i.e. you somehow stumble on the exact mixture then in may be self sustaining. But I think the first time it misfires it's doomed to failure unless conditions are just right for it to survive the screwed up mixture.
Let me know if you think I'm missing something. My brain hurts.
You might need to have a look at the video I posted a few posts back that explains the motion of the pistons to see what I'm guessing is the problem. Keeping in mind the action of a misfire condition.
I'm going to have to do some thinking about this before I go any further. I'm not going to do any more work on it without a clear direction. Maybe some sort of mechanically actuated intake valve??
Comments welcome.
Comments welcome.
