I'd got it this far and realised the paintwork on the frames was getting a bit rough with all the work that I'd been doing. So
why not take the opportunity to keep going and complete the strip down and get it sorted.
You can see what I mean by the state of the paintwork on the frames.
The guys at work got involved in a discussion on painting and convinced me to look at powder coat. So another session in the sand blaster and off the frames and stretchers went to the local powder coaters.
That's way better and far more likely to last a lot longer, $85 well spent. They can't do two colour as the powder flashes through the holes to the other side, so it was either black or red. I chose the red as it give the contrast to the black upper parts and allows the buffer bar faces to be red. The purists will tell me I've got it wrong as these locos were red on the inside of the frames and black on the outside. But this isn't a railway buffs site so who's complaining?
OK there's some wisdom that powder coated frames can have an issue with heat. However, I'm running on gas and the burner is way up in the firebox and there's a water jacket around it. So I'm guessing the heat on the outside of the boiler gets nowhere near the 250degC they use to fix the paint.
While I was onto this second re-refurbish the spray paint job on the smoke box was showing signs of over heating after attempts to produce more steam. So that came off and was sprayed with 3M heatproof paint that goes to 650degC. That needs curing at 200deg C and using the household oven didn't go down well last time so I barbecued it. My barbeque has a temp gauge in the cover so 3/4hour at 240degC did the job.
Now I've just got to put it back together again.
Pete
