- Mar 1, 2010
- 866
- 82
John/Ron/Arnold/Dean
Thanks again for your support; another days progress to report.
I installed all the steam fittings as planned and pressure tested them. Safety valves are my nemesis and one of them leaked, probably to be expected after so long. I cleaned the seat with brasso whacked the ball and replaced it and it seemed to fix it so I mounted the boiler on the frames.
First up was a last photo of the underside with the valve gear, brakes and blowdown valves installed
Boiler installed
After the leak test it was time to try the burner. Filled the boiler and fired it up. The picture isn't that good as you can't see the burner alight with the flash
Then we had steam
[ame]http://www.youtube.com/watch?v=omqa6wT_DjQ[/ame]
First run I didn't get any pressure and the second run I could only manage 20 psi. Something is leaking somewhere. I started to systematically remove steam fittings and insert blanking plugs to work out which was causing the problem. Anyway I wasn't to un-pleased by this momentous stage until I realized I'd installed the the boiler without the boiler bands. Time to remove it again and fit them, so leak tracking can wait until another day.
By way of consolation I decided to fit the tanks and loose fit the cab
I'll give the leak tracking a go one evening in the week. You never know I may get it running next weekend.
Pete
Boiler installed
Then we had steam
Pete
