Woodguy said:Matt,
Could you post a video of the engraving process?
Ken
Sure will.
Woodguy said:Matt,
Ken
Pat J said:Below is a photo of one of the bases Ken has made, that we are shifting over into TB No. 5.
Thanks Ken for the nod to my Dad, Bob Jorgensen, who designed Engine No. 21 and built the first one. I know Bob would be very thrilled to see such work. Bob J. absolutely loved to build model steam engines and would appreciate this very much.
Bob was also in the hardwood lumber business and would love the variety of wood.
Per Ken:
"The main base is quartersawn white oak sitting on ebony feet and the engine bearer is curly black walnut."
Nice work Ken.
Team No.5, I think we are on a roll.
Pat J
Pat J said:Matt-
I have material for the crank.
No problem there.
I can also ream the holes in the flywheel for the crank all the same size if they are not already the same size.
Pat J
aermotor8 said:i would like to do the crankshafts (should i make the shafts 1/2" longer then you can trim to fit the flywheels???)and
chuck
Pat J said:Matt-
I vote go on the flywheel.
What does everyone else think?
I started making a cylinder lagging tonight.
It is a thin brass tube, and I power wire-brushed it off, and put it in the lathe (about a 12" piece) and began to part it off.
I wrapped the piece in the chuck jaws with some heavy paper to prevent maring.
About 3/4 of the way through the parting, the part snagged, and tube collapsed in the jaws. I was afraid of that, and have had some trouble with thin tube before, especially brass, grabbing when parting off.
I will post disaster photos tomorrow. I think I can salvage all but about 2" of the piece.
I toyed with the idea of mounting the dremel in the tool post and using it for cutting off thin brass tube, but I thought I would stick with the traditional methods.
I made a bracket a while back for the dremel, but did not finish it, so I will either finish it or use the slitter saw in the mill with the rotary table.
I will get it right tomorrow.
Pat J
Woodguy said:Matt,
Ken
Woodguy said:Computers. Gotta love 'em.
