PMR 5bi
PaulG
Hello All,
The PMR 5BI is is my first build. I have limited machining experience & I am hard headed about asking for help. To tell you the truth, I am more nervous over trying to type something that makes sense, than cut into a $$$ casting. I must say that I have had a lot fun working on this engine, and lost more hair too. I have made mistakes, boo boo's, tell ya later. I found getting so involved that I forgot to take pictures at points. I would like to thank all people that have contributed to the wealth of information within HMEM, newbie's to Pro's. Thank you all !!!
The following is just my opinion from one PMR casting kit: The thinner cast Iron parts have very hard edges, causing extreme cutter wear. Bronze flywheel and belt wheel's suffer from casting shift, my kit anyway. Overall a nice kit.
Ok, here we go, I should complete this project by the weekend, then we''ll see if it will run.
PMR 5BI kit as received.
I found the best wheel side, edge of hub to inner, outside rim, drilled & reamed.
I gave em spin to see how they looked, hub/rim
Turned & threaded a mandrel. snug fit to wheel bores, faced & crowned wheels.
Finished, except for set screw's.
On to flashing removal next....see you all later, taking Mom to the dentist, at 92 and her NOT wanting to go...this should be fun.
Paul
Looking forward to seeing your build progress.
So your Mom is 92 and still puts up a good fight. *knuppel2*
Good for her.
I'll be lucky if I'm still around.
SAM
Nice work Paul. Great pictures, thanks for sharing your progress. :bow:
Phil
Great start Paul.
The wheels look great from my perspective.
I'll be interested to see the rest.
I have a 5BI also waiting to be built. It'll be a while though before I get around to it. So I look forward to your build :)
Mike
Hello again, Back from the dentist, not a bad trip, Mom only only got after the office girls for accounting practices. Thanks for the comments. Please, feel free to make comments, criticisms, or whatever about my methods, set-up"s, anything... as I don't know what I am doing, I look at the print, part & go for it. I need to stop and look at big picture... I started this project on January 22 according to the camera, so this stuff is past tense. You might notice pic's at 3am. or later, up late, up medium early, 8 ... 8:30.
Ok, flashing, sprues.
I just ground them off with the bench grinder & disk/belt sander.
Before
http://i997.photobucket.com/albums/af91/pgablehouse/PMR%205Bi
/DSC02751.jpg
Paul
A little more on making or ruining parts.
Lower cylinder head, used to locate bolt holes in bottle frame & cyl. block. All done except for piston rod bore & packing gland recess, easy enough :big: The print says, " 1/8" DRILL THRU, 3/16" DRILL 5/32" DEEP" 8th in. fine, 3/16" lost my mark on tail stock, pull it back, mic the depth, .01 short, pull TS back up & crank the new cobalt drill in for a little more, sucks the drill right though the last .07 of material, Dumb, A$$ forgot to lock down TS... I had some 6061, made a new one. Now we don't have a wall of shame at Paul's shop, we have a black lagoon that keeps things like this from view, it will be pictured at post end.
When I remade the part I reversed drill procedure, I recommend drill the big hole to depth, then drill through on a part like this, just in case you forget to lock down your Tailstock...
Just outside my shop is the Black Lagoon, I deposit all bad parts here, in hopes of appeasing the rotten Beaver that chews my trees half. :mad:
You might get to see this one a LOT, I will try to change it with the seasons, just to keep thing fresh. Test, how many rocks did this old fool throw, to get the Pic.
Paul
A few more
Connecting Rod
Sawed off after drilling & tapping
same with Eccentric strap
Eccentric strap, faced one side, bored, inside groove, faced other side on mill.
Cylinder head
Slide Valve
Paul
Aaaargh! Carefully stow 'em in your 'future parts' box - the beaver are probably best appeased with a thutty thutty.
Great pictures Paul. You seem to be going through this casting kit in "fast forward" mode.
If I look carefully at the picture you took of the lake, in the background I can just make out what looks like an angry furry animal making an obscene gesture in your direction. Would that be "Bucky"? Rof}
Phil
Hi, Tel & Phil
I give Bucky that same gesture back!!! If the little bugger doesn't like the Brass hes going to get that lead pill that Tel suggests. Phil I started on January 22, sorry about that...
Paul
Great thread Paul. I've got one of these waiting...er...aging in the wings too. Just no time to get to it for now. The set-up pics will be nice to review though when that time comes. Keep up the good progress
Bill
Phil & Tel, OT. a little bit of "Buckys" fine work, I wish I could make chips as fast ;D
I had wire mesh around the trees when small, no problems for eight years. The last two years Bucky has dropped 7, dead standing 2, working on 2. I never see him, hes much smarter than Axe Men.
Paul
Hi Bill,
Thanks, I hope some of this can be of help. The worst part was the Valve Chest Cover, very hard edges, ruined a new USA cutter.
Paul
And More....
The engine base Alum. The casting was .06 shorter, as received, than finished specs. Milled both sides W/fly cutter. Thanks for the tip's on grinding fly cutter bits, nice finish. I took off .035 in one pass ?? don't know if this is wise or not?
The engine will be shorter now, so it should be easier to slide through a scale doorway ;)
Valve Cover
Cross Head
Messed up Cross Head (Beaver Treat)
New Cross Head, doesn't look as good as casting, but it should work.
Paul
Honestly Paul, I like the brass part better than the beaver treat... er, I mean casting.
Excellent writeup on the build Paul. The only PMR kit I have built is the lathe and all of the castings were aluminum. I had read another post some time back where the author was having trouble with one of his castings. It was recommended that he send it back to them as they are good people to deal with.
gbritnell
Nice work Paul, I had similar problems the last time I tried to use castings, I was pretty young at the time but it put me off enough not to attempt anything with them again in the last 12 years! I'll have to do a similar project to yours to get into the swing of maching castings one day though I guess.
Twmaster, gbritnell, NickG
Hey, Thanks for your comments, just trying to learn. I bought the casting kit because looks like one used in the family sawmill, 1930 ... 1960. The engine ran the trim saw & two chip conveyors. Starting to think about a semi-scale replica. I enjoy making parts from rod & bar stock, but the castings require a lot more pre-planing, on my part anyway... especially when the darn things are under finished size to start with.
Paul
Hello All
Cross Head: I don’t know where I messed up, bad calculations, backlash, it happens. I use a Hermann Schmidt edge finder, seems to repeat well, just part of being a Grub at this. I guess you just keep making bad parts, until you learn how to make good ones. On the new Cross Head, I had to pull out all the stops, no DRO, just dials & indicators. Turned C/H OD & sides, back in mill, find center, and added this stuff.
The new one was spot on ???
Small, short parts are hard to see under the quill. I have developed a bad habit of using the drill chuck to hold end mills under .250 to facilitate clearance & vision at times. I admire the members that make little bitty parts, you guys are awesome!!!
Cylinder Block: I lightly faced one end, same on OD. measured everything , flipped it end for end, faced, turned OD, and bored .004 under. Flip, and finish other end. Turned a Mahogany dowel, snug fit (that was a mistake, to tight) and lapped cylinder. I started with valve grinding compound. I handheld the cyl, that lasted about four seconds, seized, put a strap wrench on cylinder, lathe in back gear and give it a go. After 1… 2 minutes of sliding it back & forth on the lap, and one end to end change it was to hot to touch. Cooled it down, mic it .003 over. Well crap, I am not a machinist, just Grub, no piston yet anyway, more surface area, more power!!! Next compound used was Meguiars Heavy Cut Cleaner #4, used on auto paint, then finished with Brasso. The final bore size is secrete, unless I get tech inspected at some steam engine competition.
I almost messed this up, we will see. I believe that I bumped the hand wheel after setting up the cut, yep, forgot to lock table. The 20deg. Angle hole, end of cylinder to valve port. The cutter just took a little chip out of the port side, inside the steam chest.
Paul
