TonyM your question got me to thinking that I have the perfect engine to compare different compression ratios in the same engine.
I used an online calculator and this shows my original design with the piston at TDC and being 0.500 below the end of the cylinder.
I then removed the piston and rod and shortened the rod by 0.225 so now I have a gap of 0.725 from the top of the piston to the end of the cylinder.
This is the result.
I was hoping to see a slower idle speed but I did not. The engine was harder to start and was more touchy to carb settings.
I have since reverted back to the original settings.
Thanks for looking
Ray
This is the result.
Thanks for looking
Ray
