I'm working on a project where I have small metal screws going into nuts embedded in a plastic body. I don't want to use a normal threadlocker like the blue Loctite since I won't be able to keep it off the plastic as I assemble the two parts. I've done some research into plastic safe options for threadlockers, and the best recommendation I've found thus far is Krazy Glue. However, in my own tests, it doesn't seem to provide much threadlocking strength.
So, what are my other options here? I have access to the heads of the screws, so I was considering just putting some hot glue on each to keep them from turning or vibrating loose.
