You should research the history of iron founding , and in particular the life of Abraham Darby. The amount of charcoal required to produce a ton of iron decimated the forests of England and Wales.
The impurities in coal , particularly sulphur , meant that it could not be used as a smelting fuel until Abraham Darby discovered how to use coke in his blast furnace.
This is recognised as one of the factors that started the industrial revolution , or as some might say the beginning of the end.
If you are ever in the UK try to visit the Iron Bridge Gorge where the remains of the original blast furnaces can be seen.
Incidentally my first forays into metal melting some 60 years ago used coke as a fuel , it was readily available as almost every town had a gas works.
A 10 foot stove pipe provided all the draught required to melt brass or bronze with a pleasant quiet of operation that was almost therapeutic.
You would be hard pressed to buy coke in the UK now.
Dan.
