Piston ignition points?
Niels Abildgaard
A combined power and heat plant and a powered para plane opposed piston engine will both benefit from spark plugs in center of pistons.
Has this been solved before and by whom?
    61.3 KB
Fairbanks Morse 38D.
Submarine engine.
    82.3 KB
    250.1 KB
    19.4 KB
    13.4 KB
    28.8 KB
    18.1 KB
https://www.pattakon.com/pattakonFly.htm
This guy has a bunch of different 2 stroke designs.
Haven't seen one fly though.
If a opposed 2 stroke is built like 2 normal ones then I don't see how it wouldn't work like a normal one if that makes sense...
So maybe a good starting point for you?
If it's a uniflow design as your cutaway shows then your need either a blower for scavenging or connect the 2 crankcases to the intake port.
Maybe a stepped piston could be used to get more volume in one case.
But then you don't have petroil lubrication in the other crankcase...
While on a normal 2 stroke you would need 2 exhaust pipes, however some what smaller.
A strongh and light couple will also be needed between the cranks for a flying machine, maybe the only disadvantage of the opposite piston design for your application.
Beside that I don't see any problem with your idea.
I like the triangle FBM, but this diamond shape Opposed engine makes me dizzy just looking at the drawings.
I have been planning one myself for some time.
I have spark plugs for an oil burner that reach to the center of a firing chamber. One could make such a plug.
The way gasoline conflagrates, I doubt it matters.
After years of runing, it could make cylinderbl wear when the fire starts at the edge opposed to center.
    675 KB
I have seen this Morton Model, I think he had a single spark plug.
A piston trip igniter, (Google Piston Trip Igniter) is what Niels seems to be asking about. That is made by a piece of tungsten on a spring type fixed post, insulated with a coil wire attached in the center of the head and a grounding post with tungsten on it, fastened to the center of the piston, so when it passes the post, it breaks connection at a set in time location to create spark at 10° advance.
When I Googled piston trip igniter, I came up with this from a posting here in the break room forum. There seems to be a few threads on the subject.
    1.4 MB
Picture of my proposed 2kW,one family micro combined heat and power plant has disappered so here comes again.
The two generators are paralel coupled and synchronize the two cranks .
Crankcases,generators,ignition etc comes from two portable sets with 34mm strokes.
I am not sure how they look in detail but not very new or different from sketch
The new and strange parts are mostly lathe things and I have a lathe with 48mm spindle hole
42.2 CCM gensei
If You want further information please mail.
