Got the throttle barrel made, First step was to turn it to size and then drill a 2.5mm hole and then tap for a 3mm hex bolt then I put it in the 4th axis because I didn't want to setup the dividing head
So I didn't have to worry about the angel difference between the venture and the slot, after the milling was done I then parted it off and then drill the 1/8" hole in the other end
The weather is cold at the moment, not that good for being outside (hate winter)
View attachment 157833View attachment 157834
View attachment 157837View attachment 157838
Still need to do a dit of sanding work on the carb body to take the marks out of it
