In the US, 4130 Chrome-Moly tubing is readily available from McMaster-Carr and Online Metals. The cylinders are designed around the stock size, leaving only lapping to dead-round.Not sure where I would get 4130 aircraft tubing from
What size was the prop used on the engine?I did the same. Make an extra in case of "casualties." My extra cylinder used threaded ports for intake and exhaust. These didn't look very neat, so I switched to the flanged connection. I may still use it for a single-cylinder version.
BTW, I'm amazed to see your CNC at work. Your photos and videos are great!
Totally agree. His CNC work has inspired me to leverage an old CNC mill I picked up last year and am still learning on. I love how Michael employed a jig to mount parts on for milling and flipping over for the reverse side op. Ingenious!I did the same. Make an extra in case of "casualties." My extra cylinder used threaded ports for intake and exhaust. These didn't look very neat, so I switched to the flanged connection. I may still use it for a single-cylinder version.
I speed the videos up to 20x or 8xIt's coming together well
How many times are you speeding up the videos as people may be getting the wrong idea of how fast you are running things at. I thought it looked fast the other day and now seeing you in this one has confirmed what I thought.
Nice. I switched over to FreeCAD once F360 started taking away functionality in the hobby version. I had to develop a post processor in the Path (cam) workbench module in the application. It now works well at converting the model to G code that works with my Dynapath Delta 40 Mill control. I did a quick test of the PIP slave rod, below.I have started to model the carbs in fusion360
That part looks good, only a few more to go and you have an engineNice. I switched over to FreeCAD once F360 started taking away functionality in the hobby version. I had to develop a post processor in the Path (cam) workbench module in the application. It now works well at converting the model to G code that works with my Dynapath Delta 40 Mill control. I did a quick test of the PIP slave rod, below.
Any complaints with the bench top CNC lathe? I have a manual 13x48 LeBlond but would love to have an affordable CNC lathe.I speed the videos up to 20x or 8x
The cycle time to cut the two slots using a 1/8" end mill and then a 1/16" to clean the corner out was
2min 27sec, the video speed was 8x faster so it came to 31sec
The reason is it cuts the file size down and also I tend to think people don't want to watch a video that is 5, 10, 15 or longer, minutes
I don't do it to try and make someone think it is a fast process or a fast machine, I thought it helps to show the setups, the mill and lathe have been converted by me
Maybe I should mention the actual cycle time with the videos
This is the Mill
This is the small lathe
No complaints nowAny complaints with the bench top CNC lathe? I have a manual 13x48 LeBlond but would love to have an affordable CNC lathe.
Looking great! The side plate and fuel inlet appear yellow in the photos. Are they made from brass?A little more work on the carby today
Got the fuel fitting and the cap to plug up the hole in the side plate, I used solder paste to solder these in place
I hadn't used the paste type solder before, it worked quiet well and there was no clean up after with solder running all over where you don't want it
First I made a fixture to hold the side plate at the right angle 25°, drill a .078" through in to the fuel passage, the a 1/8" .078 deep for the fuel fitting
View attachment 157651View attachment 157652View attachment 157653View attachment 157654
View attachment 157656View attachment 157657View attachment 157658View attachment 157660View attachment 157661View attachment 157662View attachment 157663View attachment 157664View attachment 157665View attachment 157666
Yes it is brassCurious if you couldn’t use a small boring bar or
I’ll prolly just use low temp solder when I get to this. It requires less heat and the capillary action does its thing. I’m currently building an arbor for my Quorn T&C grinder. I have a new 46 grit cup wheel I’m going to use to rough the fin cutting bit from a 3/8’s hss blank. I have fine grit wheels mounted on arbors but they load up pretty quickly when taking off a lot of material.Yes it is brass
It seem to get more of a yellow gold look after heating to melt the solder
