Cogsy
Flywheel spin test looks good to me too - not much drag in those bearings even with the grease.
One more thing, in the video I see the surface of the hole air intake seems not good. If the surface of the hole air intake and slide valve is not straight , it is difficult to seal , and will not create vacuum.
You should place the sandpaper on a flat surface ( glass ) and grind it to the straight (first with sandpaper 100, then sandpaper 600).
Thanks. I'll turn it to a loose fit in the cam roller.
The cam roller came out pretty cool looking in the rotary table. I was trying to figure out how to cut that relief between the hub and the outer rim, and a friend said "you're going to put it on the rotary table to drill those holes, can you just mill a ring there?" I used a 1/8" HSS end mill and it worked fine.
Edit for writing error. 1628 EDT
What thickness material did you use for the valve shim thing as again to thick and the engine wont be able to exhaust
Until now, everything I see and hear you say is perfect fit with the way I do flame eater engine
I really only have one
You adjust the valve a little bit forward ( or backwards ) and run it, bit by bit.
You will find a position that seems like it wants to run, continue to adjust the valve .. and position the flame. BUT: make sure everything is smooth, and air tight. It will run
Flame eater is a difficult engine, Just think in your mind: it has very little power, reduce the friction and air tight as much as possible !
as fcheslop has said: "Good luck they are frustrating little beggars to build but great fun when they run"
Does the valve rod slide in the hole thats machined into the cylinders upright?
Is the valve rod parallel to the flat machined on the cylinder
Just wondering is something is out of square and jamming a bit
cheers
frazer
Thanks, Al.When I built my Jan Ridders one, it took many hours over many days to get it to go, even when I was certain it was all correct. The flame position on mine is extremely touchy and if it's a bit off it just won't run.
Once the binds are sorted when you spin the motor over you should hear a definite and sharp quacking farting noise this is the engine exhausting
