With large diameter steel wire,I think you should make the diameter of the spring larger in the middle and only smaller at the two ends, when the diameter is larger, its tension will decrease.
For burners I like to use copper pipe reducers as they are cheap and available
The original burner canbe adjusted by pivoting it around.The flame needs to be as close as possible but not touching the valve
The spring on my engine is as rough as a badgers backside but looks a lot finer wire than you have used I think it was wound from a guitar string
I found on my first few runs as it bedded in the timing needed retarding or else it rattled along the bench
I v attached a link just to show the fittings as I dont know what they are known as in youre neck of the woods
https://www.google.co.uk/aclk?sa=l&...hUKEwipoKKIlY7dAhWSLFAKHfGPDcwQ9aACCDo&adurl=
Not sure if youve seen this but it maybe of some use
http://www.deansphotographica.com/machining/projects/springs/springs.html
Now ,
I think :
Did you check that the valve and the piston are airtight? In the video, I feel it does not seem to make a vacuum (- the flywheel turns back only when the spring is compressed, and it is not vacuum)
Like Cogsy said, "The thing I notice is your flame looks pretty yellow / orange in the video, what fuel are you using? I use ~ 95% alcohol and the flame has more blue in it, so is likely a bit hotter coal yours.
As for the timing, some air has been expelled from the port at the top of the stroke to get rid of exhaust gases so I would not be concerned about that. "
I adjusted the slide valve for my engine (and I think it's the same as your engine )
"" 4. The adjustment of the flame-eater.
The correct movement pattern of the slide valve in the 360° cycle is crucial.
The valve must open the flame hole in the cylinder about 30° before the piston is in its position closest to the cylinder head. The reason for that is that the cooled flame gases also are compressed again to atmospheric pressure during the working stroke of the piston already before the piston has reached its end position. If the flame hole is opened too late a counter-acting pressure will occur in the cylinder; the engine slows down or even stops running than. This opening of the cylinder hole through the slide should preferably be as abrupt as possible. During this 30º the cooled gasses with atmospheric pressure escape trough the flame hole to the outside. The valve must close the flame hole again at the time the piston is arrived again at 20 to 30 º from the other end side of the cylinder.
The overlap of the valve over the flame hole at the time that this is closed needs to be close to zero. I even have the experience that the motors run better if there is a very small gap left with the thickness of a human hair! For this phenomenon I still don't have a good explanation yet, presumably this also has to do with the occurrence of any counter-acting pressure in the cylinder.
The pressure of the spring(s) that holds the slide valve against the cylinder surface need to be adjusted so that the valve moves very well parallel along the cylinder surface but with a minimum pressure to minimize frictions. In fact, the valve only needs to be kept in place because the partial vacuum in the cylinder will pull the valve to the cylinder surface making a good leak free contact.""
For more :
Link
http://ridders.nu/Webpaginas/pagina_ervaringen_tips_happers/ervaringenhappers_frameset.htm
And one more thing, in your video I feel like the engine does not move as smoothly as my video.
