fcheslop
Hi Bob, the cam can only go on one way as you correctly say. The engine will run or at least my engine will run at any position on the adjustment slot it just goes faster oneway and a wee bit slower the other
One problem I remember was that I adjusted the valve to come to far forward it only needs to fully cover the port by about 1/64 thats the leading edge of the valve I set it wrong and it wouldnt run or ran erratically. I think I had a problem with the shim bit that holds the valve I bent it up slightly wrong but maybe Im wrong as its 20 years ago
It must be lubricated with graphite anything else kills it .I just use a 4B pencil and scribble around the piston again to much graphite chokes it up hence just using a pencil. I also lubricate the valve face the same way
It needs to spin freely any binds will stop it running even the slightest
If you need a pic I can to one or two Sunday
cheers
frazer
cheers
frazer
