Just a brief update today while my lunch is cooking (beef, cheese and bacon pie in the oven as we speak). I decided to tackle the backing plate, or, as we used to call it, the sandwich plate between the block and the bell housing.
I started by chucking a bit of rough sawn (hand sawn
) ali plate in the 4 jaw, with enough offset to have extra material all round, and drilled the crankshaft through hole. I marked the approximate edges and hole location with a sharpie just for ease of setup in the chuck.
After facing the whole plate flat I kept taking what were basically facing cuts but leaving the raised centre section to locate the ID of the bell housing. Once that was done it was off to the mill to cut the basic outside shape of the backing plate.
Once I'd drilled the mounting holes, I removed the part from the vice remounted it in a vertical orientation. In fact, I had to reorient it quite a few times to cut the various angles, cutaways and chamfers.
Once the outside had the correct shape, I remounted it horizontally in the vice but upside down to what it had been. Then it was a simple matter of face milling it down to required thickness, which removed all the extra material as well. A quick hand file of the upper 'tang' chamfer and it was complete.
As the backing plate was a relatively quick and easy part to make, I followed it up with another simple part - the flywheel. The hardest step was the first one, where I had to hand saw a lump off a piece of 40mm tool steel. It's decent stuff to machine but incredibly tiresome to hacksaw.
I turned it to major diameter, drilled the centre and recessed for the retaining nut. From there, although I didn't take a picture of it, I cut a series of steps by eye as the rear face of the flywheel is a domed shape and I still haven't made a radius turner yet.
I blended the steps using a file under power, then cleaned it up with sandpaper to a very nice finish (if I do say so myself). This part is entirely contained within the bell housing and is not visible on the completed engine, so it really wasn't necessary, but the tool steel cleaned up so nicely I just couldn't help but polish it.
Again I didn't take a picture, but after parting it off I turned it around, faced it flat and cut the 10 degree taper to mate to the crankshaft to finish it off. I can't take a picture of the finished flywheel now as it's currently hidden inside the bell housing which I've installed just to see how the whole engine is looking so far. My pie is now ready so I'm off to scoff it down!
Edit: I thought I'd better include a picture of the mock up since I mentioned it and someone might be interested.
