bug_hunter
We may need to move this to Boilers questions and answers forum?
I concur. Once I am well along on the engine, I will start a post on that forum. Thanks for all the insight.
Greg
Are you close to Green Bay ?
Glad to be of assistance. looking forward to see your first engine.I concur. Once I am well along on the engine, I will start a post on that forum. Thanks for all the insight.
Greg
"Maybe I m missing something here, but they do not state the Normal Working pressure for their boilers..."Just a comment on the PM Research boilers. They say they provide "Silver Solder and flux" with their kits. I assume this means high temperature silver solder and flux - that works around 630~650 degrees C for the lowest melting point SILVER SOLDERS that I have seen listed. Maybe I m missing something here, but they do not state the Normal Working pressure for their boilers... and supply a Safety relief valve but no pressure gauge. I GUESS these are for less than about 15psi use (domestic pressure cookers and coffee machines work below this pressure to minimise pressure vessel legislation - I think?).
Toy boilers and engines in the UK work at such low pressures.
But I should advise that (IMHO) ONLY high temperature Silver solders should be used for any boiler over 15 psi, as the "soft" solders containing tin lose too much strength at the temperature of steam at 15psi.
I made one from a motorcycle brake master cylinder. I added a check valve at the boiler. Works great!...
Add on question: When performing a hydrostatic test on the boiler, where might I find a small, manual pump to generate the required 120-180 psi? More of a do-it-yourself kind of guy, so the $75-$100 test kits on Ebay don't really interest me.
Good Idea I had never thought of that one. I have to give it a try.I made one from a motorcycle brake master cylinder. I added a check valve at the boiler. Works great!
"How to make a mountain out of a molehill." ask K2 aka SteamchickIn the UK, I can't get a boiler tested with any "soft solder" (low temperature alloy).
60/40 electrical solder is quoted as:
60-40 Soft Solder (60 Sn-40Pb) - ASTM B 32 Grade Sn60
Just found "4% Silver-tin" solder. (Harris do not quote the tensile strength). I found this Technical Data Sheet from Canfield: 96% TIN/4% SILVER
Canfield’s 96/4 solder is cadmium free and lead free. This alloy has a bright finish, is a perfect colour match to stainless steel, and meets high strength requirements.
TECHNICAL DATA:
Temperature Range:
430deg.F. (Solid to Liquid)
Shear Strength: 11,200 PSI (Room Temperature)
Tensile Strength: 15,000 PS (Room Temperature)
Not found it in the UK though... Any idea of tensile strength at 367deg. F? - Assuming metal can get 60deg.F above the Steam temp of 307deg.F at 60psi?
Another:
Kapp product is quoted with a tensile strength of 14000psi... and:
Applications
It does NOT mention any application like the temperature of the steam boiler. The nearest may be "copper plumbing pipe" - the hottest may be 212deg. F? (Not stated, so who knows?).
- Hand soldering Copper wires and tabs when the application could require more time to position the item being soldered
- Electrical and electronic applications
- Applying thin Copper and Stainless Steel wires to circuit boards
- Typical uses include:
- Electronics
- Fabrication
- Ducting
- Food containers
- Storage bins
- Instruments
- Copper plumbing pipe
- Cooling coils for refrigerators
- Paired with Kapp Comet™ Flux
But then one hopes (expects) that there is a proper Engineer at PM Research that warrants the boilers with this solder, for 60psi (307deg.F. steam temperature).
The thing I like about ASME... is that it is recommendations from scientists and Engineers. Not politicians. (as far as I know?). So if it works for them, it should be safe for me.
On this site, or any other public forum, it would be wrong for me to propose, condone or say anything that is below the standards I know to be "safe". Hence I quote ASME. If I am wrong there are plenty to correct me.
In the UK I am not bound by ASME, but just the laws of physics and BS. (That is the "British Standards" - not the "Brown Smelly" BS...).
Thanks,
"Sorry if I have upset you, that was not my intention."Hi wce4.
Sorry if I have upset you, that was not my intention. Take a big breath, remind yourself that I am "just ----- who doesn't know what you are about", and lets's discuss this calmly.
I was hoping this alloy was something with enough silver that I could use it on a boiler that needs a modification, before my Boiler Test Engineer will test it for certification. (His requirement is simply "Silver Solder). So I was looking for something from various manufacturers of this solder in case someone stated "OK at 200C" or "tensile strength at 150C" or Max. temp (whatever)...", or something?
But only to have a boiler maker say he has "not had a problem in the US" did not fit what I need, as I am in the UK. Actual technical data would have been good (internationally recognised). But there doesn't seem to be any readily available so I'll just have to use the big Blowlamp and use my regular Silver solder at around 650C to make the mods.
Once again, Sorry I upset you.
For myself and plus I have the equipment, I now TIG welded my copper boilers. But my first and second boiler I used PM Research 4%, still holding strong, still do a hydo test every year tho. Better to be safe than sorry.Boiler threads are some of the most contentious posts that I have ever seen.
I recall some very high spirited boiler posts in the past.
There does not seem to be much middle ground in thoughts about boilers and boiler safety.
I don't think soft solder should be used on any boiler, just because if you are not paying attention, and let the water level get a bit low, then the boiler will fail. I have personally failed a boiler this way and almost been blinded.
My dad built boilers; I have built boilers, and I plan on building more boilers.
I won't discuss how I build or have built them, other than to say I felt comfortable with operating them at 100 psi and less.
The biggest problem I am aware of is corrosion on the end plates, and that is a very real problem that can fail a boiler over time.
I saw someone decide to build a boiler from stainless steel, and I have seen enough information to convince me that a stainless boiler should not be built.
Silver-soldered boilers (with high-temp silver solder) seem to be the norm for many, with copper construction.
The problem with silver soldered boilers is getting all the joints perfect, and getting one joint done without affecting a nearby joint.
I have seen folks online totally botch the silver soldering process on small copper boilers.
I saw a steam bike with a boiler that operated at 1,200 psi, and the water tubes were square on the end.
Extremely scary build, and not safe by any measure to use flat ends on piping or anything that is not well supported, especially in a high pressure boiler.
I don't think any hobby boiler should operate around the general public at more than 100 psi, and I would personally not operate a hobby boiler above 50 psi.
I have seen TIG welded copper boilers, and I know that is a viable method if done correctly, with a TIG machine that had sufficient current to overcome the heat dissipation of the copper.
I have seem much discussion about using a safety valve with enough area to relieve a boiler that is in an overpressure condition.
This is very important.
I have seen safe boiler builds that were copied by other in an extremely unsafe way, with no safety valve, and no water sight gauge.
That is why I don't post boiler designs online.
And I have seen posts of certified fire tube boilers, and they have very thick end plates, some very careful welding, and the correct fittings in all places.
And laws about boilers in general, and boilers at engine shows, vary by country, and by state.
And I know of folks being killed by steam tractor boilers exploding at shows, and thus the push to tighten up on safety of boilers, especially old boilers that may have hidden internal corrosion.
I get the safety aspect of it, and so in general, I would recommend that if you build a boiler, stay within your skill level, and stick with a design that is used by others and proven to be an effective and safe design.
One of the better boiler references I have found is The Steamboating Forum, where they build full size boilers of all types, and use them to power boats.
They have a lot of experience about which boilers work well, and which don't, and they can explain what works well over time, and what does not.
Good luck to all, and be safe.
