Hi Guys,
I am a new member. I found this site by accident looking for some plans for a steam engine
for a Trade Engineering training course I started this year. After we have learned the basics
of lathes and mills and done a couple of starter projects we are allowed to make a more complex
project to learn more about the machines and Engineering in general.
I live in Australia on the Eastern side about half way between Sydney and Melbourne in a place
called Wodonga. It is on the main highway between the other two Cities. I have been interested in
Engineering for many years but this is the first opportunity I have had to actually study it and I am
so far having a ball. I had previously taught myself how to do CAD drawings in AutoCAD but now
have learned Technical Drawing and understand the CAD much better. I am interested in the Design
part of Engineering and how things work.
I am very much enjoying my course. I have so far made only three Paperweights and one of them was
on purpose. The first was a Project to face and machine down a mild steel bar to specific diameters to
learn about measuring and precision. It is just developing surface rust now. The second was a broken
cutting head on a Boring Bar while boring the inside of my Tap Wrench project. After changing the
cutting head I developed a "step" inside and while "fixing" it I managed to overbore the front of the
wrench too wide so the jaws would no longer close - a few weeks work gone in minutes. The last was
after facing a new piece of mild steel and breaking the drill bit while drilling the centering hole. I am
getting REALLY good now at using the Band Saw to cut Mild Steel Bar.
The Machine Shop has only tried to Kill me once. While learning how to use the Mill and sawing the
slots in the jaws of my Tap Wrench, the saw blade came loose and the vibrations loosened the whole
spindle. I called my Instructor over when it started to make loud strange noises (We learned THAT
in week 1) and he caught it just before the whole spindle dropped out and the cutting blade fell off.
Ignorance is certainly Bliss as the other Instructor had coniptions when he heard what happened - I
had no idea how close to Death I had come (it was only spinning at 1100 rpm).
Now I realise that this is a place for sharing, and before my School gets a bad name there are a few
things I should point out. Firstly - it is a School and we ARE supervised and all of these particular
machines are brand new. Secondly - the machine WAS checked after set up and everything was tight
and apparently doing what it was supposed to do. Lastly - we learn by making mistakes and trust me
students AND Instructors learned from that one.
So finally, what made me find this place? Well even though we have so far learned some relatively
simple machining stuff, the Course is not only Theory but very hands on and we are encouraged to
make things in the interests of learning. One of the Projects offered to us after we finish the Tap
Wrench is a Steam Engine. This interested me but when I saw it the design was a fairly simple piston
driving a flywheel in a flat configuration I thought I could find something that was a bit more of a
challenge and looked cool but not too difficult for a first major project. So I popped on my Google
Goggles and went looking.
I stumbled upon this site quite early and came across Brian Rupnow's Beam Engine and thought
it was pretty cool and was fit for the criteria. The only problem was it was in Imperial measurements.
(Feeble attempt at Humour)
There are only Three Third World Countries that do not use the Metric System, and the United States
is one of them!
(End Feeble Attempt)
Since I live in Australia we do use the Metric System and I needed some free plans of a similar
Engine in Metric, so I kept looking. I have finally come up with a Metric version of Gerry's Engine
that is based on OldBoatGuy's plans and drawn up by Ken from South Africa Thanks for that, except
they are on one huge AutoCAD sheet which is no good for individual Parts in a Machine Shop. I am
currently transcribing these plans into a series of A4 and A3 sheets and I will make them available
when I am done to the rest of you. My Plan is to build this Engine as my School Project so I will
keep you all informed as I go/when I go/If I go as it has to be OKed by my Instructor.
Well that is about it for now. Nice to see you all. I just have to work out how to get an actual
File List instead of a heap of Post Threads that sometimes link to a File. Your help would be
much appreciated. Everytime I go to the Downloads link I just get Message Threads.
Andrew
