Swifty
I'm with you on the gambling Gus, I'm just not lucky, I lose my money every time. I don't mind playing a couple of dollars but that is where it ends.
Paul.
Paul.
Gus--I share your regard for your fingers. Mine are old and arthritic, and one has been removed with an axe and then re-attached in the ancient past. However, I love them all dearly, and have no desire to part with any of them.--No propellers for this kid!!!----Brian
Hi Gus, I hate to be the bearer of bad news and upset your evening, but the bottom flange is 60mm dia, the same as the rest of the cylinder. The 55mm dia is to the bottom of the first few grooves at the top. My M4 screws have a head dia of 7mm, this would mean the screw heads would nearly fill up the step completely. You may be able to machine a bit more off the 40mm recess dia to give some clearance. If you use 48PCD for the holes, plus 7mm head dia, this will make the outside of the screw heads 55mm dia.the same as your flange. You may have to taper the last few fins in order to get a screw and hex key in. I did mention in an earlier post that all lines are drawn solid, this makes it very confusing.
Paul.
Split ringOr just skim down the 40mm dia waist by 1mm then you can fit the intended socket head screws.
Can't see how that ring will fit over the flange Brian ?
