- May 27, 2010
- 2,999
- 1,171
Excavating the crankcase cavity was a very tedious job with the fear of destroying job with last cuts of the day.
Did not dawn on me to use two fluke end mills. Was using 4-f mills and quill cuts with table hand feed.Cavity cutting took total of 8 hours.The quill feed max out at 10 mm depth. The depth of cavity was hard to gauge.DIY a mini slip gage and adjusted quill
for the cut. Turned out to be OK.
Had to stretch & coax the Sakai,Japan Mill to cut crankcase. Would be great if I still have the BridgePort Mill,Leblonde 12 " Swing Precision Lathe and a big machineshop.Have to adjust and live with mini lathe and mill in a balcony shop.:rant:
![IMG_0744.jpg IMG_0744.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/25/25896-IMG-0744.jpg)
![IMG_0746.jpg IMG_0746.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/25/25897-IMG-0746.jpg)
![IMG_0749.jpg IMG_0749.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/25/25898-IMG-0749.jpg)
![IMG_0747.jpg IMG_0747.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/25/25899-IMG-0747.jpg)
![IMG_0750.jpg IMG_0750.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/25/25900-IMG-0750.jpg)
![IMG_0753.jpg IMG_0753.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/25/25901-IMG-0753.jpg)
![IMG_0752.jpg IMG_0752.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/25/25902-IMG-0752.jpg)
