BaronJ
Grumpy Old Git.
Hi Gus,
Do you want a copy of my PWM speed controller circuit ?
Hi Gus,
I like the auto return tensioner.
Paul.
You will be putting a lot of work into the cam Gus, so it's probably best to use silver steel and harden it. Brian uses O1, oil hardening, but I prefer to have all my silver steel W1, water hardening. That way there is no mixing up of different types. It's my belief that the W1 is a bit more forgiving if you don't reach the correct temperature, it will always harden a bit. You just have to be a bit careful with sharp internal corners with the W1, the shock of the water quench may cause cracks. I only have a Mapp torch, but this is fine for small components, a small hint to know when you have reached the correct temperature is when you see small bright flakes appear on the red hot surface, this is the structure of the steel changing and it's time to quench.
It may pay to do a small test with your high tensile bolt, just turn up a small part and see if there is enough carbon in it to harden by heating it up red hot and quenching it.
Paul.
That's great Gus, but if all else failed, I would have sent you the cams milled on the one piece as mine are.
Paul.
Hi Gus, the name Totem sounds familiar, I must have come across that brand in the past. Have a great time at TokyuHands, it may be best to send your wife elsewhere when you go shopping.
Paul.
Gus, all women seem to be the same when it comes to shopping, "look, I bought you some socks", that's to cover up all the things that they have bought themselves.
Paul.
