The casting set I purchase four years ago at the Consignment Sales Area of
Cabin Fever Model Engineering Expo Show, It seems that the person who had it before me
tried to bore the cylinder,in doing so the bore is off center.
If I were to rebore the cylinder to correct it, it would make the bore about 0.037"/ 0.940mm oversize.
I am looking for recommendations from you real model engineers on here what would you do?
#1: Bore it over size and machine the piston to fit? or
#2: Bore and sleeve it and keep the piston to the design size?
If so what diameter should I bore it out too, and what size should I make the sleeve?
The cylinder is cast iron.
