No machining today,
start capacitor went kaboom on the lathe.
Pick up a replacement , I will be back up running tomorrow.
Jasonb I really like your Idea on machining a rectangular pocket and fit proper split bearings with retaining plate. From where I'm sitting it looks better than the original design. I might just change it on my engine after I finish it as design.Thank you.
Thank you for the dwg. I will add to my steam engine dwg files and use it for future reference.I tend to go with separate caps, either flat which look similar to the Stuart extrusions, this was drawn with the intension to cut the sole plate from solid.
Or you can add a bit more shape to the caps like this one I fabricated
Jasonb you are 100% correct. It's aliveShould be running by tonight at your rate![]()
A classic for the ages!Did you get the correct brain for it?
Craig
Thank you GreenTwinRuns very nicely, and no flywheel wobble either.
Great job !
Thank you minh-thanhThe engine runs great.
Congratulations !
Thank you ShopShoe ,was a pleasure posting my build on the site.Congratulations on a good runner
Thank You for posting.
--ShopShoe
Thank you paulrayner , The next project is, see attach pdf file.well done. what's your next one?
nice one. will enjoy following your buildThank you paulrayner , The next project is, see attach pdf file.
